ML Mirror removal
M
mboy
I have a ML270 2002, does anyone know how to remove the mirror glass from the bracket?
Thanks.
Isnt this the one where you push the glass in at the bottom and unhook the wire spring that runs across the top, and you lift the glass up and out
M
mboy
I followed your instructions and it worked, perfect.
Thanks alot,
Mas
M
mboy
Just one more quick question, I have condersation in the left headlight. Do you have any ideal how that happened? Is there anyway to clear it?
Xtractorfan
S class
Providing the headlamp lens and body is in good nick and no splits or cracks the most probable item to leak is the seal on the back where the bulbs are fitted, check the seal is properly fitted and not broken,,you can dry out the lamp with an airline or hair dryer
leaving the light on will also clear it
www.W140.co.uk&www.r129.co
