ML Squeak
MarkF
Rhyl, North Wales
ML 270CDi
My ML has developed a squeak from the front offside suspension.
It is more audiable withnormal driving rather than over bumps and if you rock the car hard you can get it to squeak.
Any ideas?
kebo57
Lanc's
ml270
Hi have you checked the anti roll bar bushes
Kevin
luders79
London
W210 estate
possibly a bottom ball joint? have had one give the same type of noise!
MarkF
MarkF
Rhyl, North Wales
ML 270CDi
Guy's,
Thanks for the info it could be the ball joint as it was mentioned at the last service as having slight play, I am popping over to the indi in the morning as working from home so will see what he has to say.
Regards
Mark
MarkF
MarkF
Rhyl, North Wales
ML 270CDi
Bang on Guy's
Had the car at the indi this morning, the front offside ball joint is the problem, quite bad and would not pass a MOT, the nearside has slight play but the car is booked in for both to be changed on Saturday morning.
Thanks again
Mark
kebo57
Lanc's
ml270
Bang on Guy's
Thanks again
Mark
Hi I did a how to for the front ball joint on a ML
http://forums.mercedesclub.org.uk/showthread.php?t=44323
I would be interested in the price for this job
Kevin
roscoc180
Cornwall
R230 SL350 black/blue-2004
Kevin
I have a squeak on my SL, bottom ball joints ok. You said anti roll bar bushes, what can go wrong? I have just replaced the outer ones so I take it could be the inner ones. Can you tell me what to look for please, the squeak seems to be worse after I have driven the car for a few miles.
kebo57
Lanc's
ml270
I was relating to the ML but I have replaced the outer ones with none genuine and they only lasted a couple of months, I have never had any trouble with the inner ones on the ML
Kevin
MarkF
MarkF
Rhyl, North Wales
ML 270CDi
How easy of a job is it to change all the anti roll bar bushes, How do you get the end ones out?
Regards
Mark
I will let you know on price as its going back on Wednesday, the track rod ends have sized up and they run out of time on Saturday to do the tracking.
kebo57
Lanc's
ml270
Regards
Mark
Hi the front outer / end rubber bushes are clamped in position with a bolt that clamps the housing that covers them, if the bolt comes out without sheering off then they are easy to change, if they sheer off then you will be drilling and re-tapping as I had to do & replace with s/s bolts
The bushes have a flat side their not completely round its a bit difficult to see on the picture
Kevin
MarkF
MarkF
Rhyl, North Wales
ML 270CDi
Kebo,
Thanks for this, I will have a look when I get 5 as I think they could do with replacing.
Regards
Mark
MarkF
MarkF
Rhyl, North Wales
ML 270CDi
Well spent 2 hrs at the indi yesterday morning while he worked on the tracking, the track rods had sizzed, never been adjusted since I have had the car but as they replaced the ball joints they wanted to set it up ok.
Anyway the short story is the car drives ok now as it did used to pull to the left slightly but now when its straight the steering wheel is around to the right. They are taking it to put it on the 4 wheel alignment jig next Thursday so will wait and see what happens.
The ESP light is on now but he did say this is because the steering is ok.
Will keep you posted.
