Hercules
- Dec 4, 2002
- Location
- London UK
- ML320/2006-w203/2006
Hello there, I have lately investigating a problem Having engine starting from cold, engine starts OK but no as quick is used to do before , it takes about 2 to 3 sec to start compare to 1 sec as usual
At first I thought it was the battery and I replaced it last March,I went to the battery vendor yesterday to check the battery and it confirmed that the battery is OK it just back need recharging.
I checked the battery when I got home and the voltage was 12.8 volts engine of and 13.8 engine running at 2500 revs.
I did some research and if i understood right the voltage out of the alternator should be around 14.4 volts.
Is the regulator need to be replaced or is OK ??
