andrew056
- Jun 7, 2010
- Location
- Devon
- 1993 SL320 gone but not forgotten , 2004 240 CLK cabrio, 2006 ML 320cdi gone, GLC AMG 43
- Thread Starter
- Thread starter
- #21
Chris No you don't have to take the screw out but it has to be undone . Where the screw sits in a hole just in front and above the hole you can see the catch , its actually metal , you can either flick it down with a long flat screwdriver through the hole you accessed the torx screw or if you prise out the reflector you can access it through there with a small screwdriver. Once you spot it its obvious! I think I might have to buy a new barrel as the key turns but doesn't move the actuator part on the other end which was stuck in the emergency unlock position hence the original problem.
Andrew
Andrew
