hello.my ml270 has long cranking no matter the conditions. if its cold,hot ,hasnt started in a week hasnt started in a minute always the same.On heavy acceleration the engine shuts off with epc light. Previously this was solved by changing fuel filter .Now i have changed fuel filter,fuel line from lpfp to hpfp , injectors have normal return and the diesel tech told me that he has seen injectors with 5 times the return amount as mine and still didnt cause problems.Rail pressure is within normal range and rises as soon as cranking begins ,pressure regulator is ok, there are zero bubbles in all fuel lines .Last thing ill try tomorrow is find a used low pressure lift pump to test if theres any change although the technician told me this fails once in a million. The car is running on red diesel for the majority of its life idk if this could cause any problems MY 2001 350000km Any ideas appreciated.
