- Thread Starter
- Thread starter
- #21
I would get the fault codes read to try and pin point the problem - could be several things.
I recently had a similar problem and had to replace the inlet manifold and inlet port motor (that shuts the flaps in the inlet manifold) This gives a loss of power similar to a MAF fault. It was reset when I restarted the car but got worse over time to a point were I could not get it out vof limp home mode.
I was also told that battery problems resulting in slightly lower voltage can cause the gearbox to put the car in limp mode
