ML270 CDI no kickdown
takeaflight
Hi I have been lurking for a while, but due to lack of knowledge I have not posted anything.
However I wonder if someone could help please, having searched the forum, it appears the MAF could be the problem, of no kickdown, max around 3000 rpm, box changes up to motorway speeds slowley but gets there.
I have read here,to try disconnecting the MAF, which I have done with no apparent effect, therefore would this surgest it is the sensor or not.
Cheers Confused of Stratford.:-?
This is a hard one, short of trying another MAF as all carss do not respond in the same way. The only other thing is to have the fault codes read out by an indie with STAR
T
takeaflight
Thanks phoned the local Benz £99 to fault read.
£59 for the sensor so might just replace the sensor first and see what happens, the part guy said that he would have the fault looked at before replacing the sensor, as it may cause the new sensor to go US.
I have taken the MAF off and all looks OK the mesh is clean, no deposits anywhere, a very very small amount of oil? on the sensor itself but other that all OK.
Thanks Roy
T
takeaflight
Hi Television just looked at your site, would you have two knobs that release the backs on the rear seats, by any chance. 02 270cdi grey leather WDC 1631132a375187
Thanks Roy
I wonder where the oil has come from,,One point nothing on the engine can blow the MAF he is telling porkies, Indies charge on average £30 to read out,,where are you in the UK
T
takeaflight
Stratford upon avon Warwickshire
I think it may have been oil, but such a small amount and very thin if that makes sense.
The only one that I know is in Nuneaton, and that is a bit far, but he is very good and you would not be out of pocket
T
takeaflight
OK went to PROSPectsolihull, nice blokes all ex merc main dealers, put the ML on the computer, found probably the MAF us, sourced one from a local MB dealer,.
Fitted all done in just over a hour. £101 in vat.
Can't complain at that.
Thanks Television for help.
drivinggod09
north wales
also i used to go to ASPI SPECIALIST CARS in SOA when i was stationd there think it was £50 for a diagnostics and all genuine MB parts used as its next door i had no problems with them.
Pleased that it all went well, thanks for posting back
www.ckinsurance.co.uk
