ML270 Loss of Power
MartyR
West Midlands
2005 ML 270, 2007 Clio 197
Hi All,
New to the forum and MB.
So I have be surfing the internet and this loss of power with the ML270 05 seems to be a common issue and seems an fairly easy issue to rectify from my reading.
However I though I would ask for advice on the problem in case I miss something and a few more ideas can never hurt.
So my ML270 is suffering a serious loss of power after driving for 5-35 mins, this only happens on acceleration and the exhaust fumes block out the sun for the poor motorist behind (Unless they drive an Audi then I don't care). After reading forum and general google fun my first though was the MAF as it doesn't seem to be burning fuel completely.
However after taking it to my local garage they said the fault suggested it was a lack of boost on the turbo, which in my mind would make sense as well and would explain the volcanic plumes of black smoke pouring out the back (I exaggerate slightly on this).
So I know the previous said that he had the turbo rebuilt recently????? the car has been serviced somewhat but judging by the air filter I pulled out I think this only happened until 2006. the only other fault code I'm getting is the glow plugs. Having looked at the turbo by recent rebuild he may mean 5 years ago as it doesn't look likely but I may be wrong.
My feeling is the turbo isn't creating enough boost so the engine is over fuelling.
Can anyone help and point me to where I should look next?
Many thanks
Martin
bembo449
gainsborough , lincolnshire
blocked cat , inlet manifold , EGR , knackered injectors , was star used to diagnose the glow plugs ??
M
MartyR
West Midlands
Hi, Not sure if it was star however he did assure me it was a top of the range scanner.
M
MartyR
West Midlands
I think my gut is telling me its boost issue but then I have been wrong about a lot of things. As I said I think the black smoke is showing over fuelling. I think I will have to find a independent this weekend and see.
Split hoses to the intercooler are a common issue. The split can be hard to see. Smoke testing the pipework is usually the best way to find it.
M
MartyR
West Midlands
So this afternoon after myself and friend decided to check the egr, turbo etc. So we discovered that the turbo was producing boost by disconnecting it to the intercooler and had boost. Next we tested to past the intercooler to the egr and again got boost.
So we noticed that the egr was caked in carbon so removed this and cleaned it out thinking it was stuck open however it was closed so no dice.
Then we followed it to the inlet manifold, there we noticed that where the engine beautification panel bolt holes are a lot of air was blowing out of the one closest to the front of the engine. Very strange but maybe normal as this is the first ML I have had.
My question is clearly this would cause a fault as it would lose boost in a system that needs pressure but am I missing something still?
Cheers
Martin
M
MartyR
West Midlands
Just to add, when we had the pipe of past the intercooler we were still getting loads of smoke. Could this be the breather pipe filter on the turbo side being blocked?
Cheers
Martin
M
MartyR
West Midlands
Just a picture of the offending part
Taffy7hfa
Oxford
Seems like a bit too much guesswork going on here, I would get it on Star and see what the live data says.
M
MartyR
West Midlands
So I have “fixed” the blow but alas still losing boost. I think getting it scanned is the best option now as i have exhausted my limited knowledge
Taffy7hfa
Oxford
Potentially lots of things it could be so Star is definitely your best option ;)
M
MartyR
West Midlands
Yeah I agree, have to bite the bullet and take it to my local MB service centre in the week. Oh how I’m looking forward to that :)
Find a local independent and it won't be such a horrible experience :) yours sounds like a boost leak somewhere but does need diagnostics to confirm root cause.
M
MartyR
West Midlands
Thanks for the steer, there is one in Tamworth so will call them tomorrow and arrange a visit :) fingers crossed I won’t be single afterwards :)
M
MartyR
West Midlands
  • #17
Well happy days I’m stuck about 3 miles from home waiting to be rescued. Diagnosis = dead battery, lights up but no turn over. Looks like it’s being abandoned for the night :)
Taffy7hfa
Oxford
Batteries don't seem to give any obvious signs of impending failure like they used to, one day they appear ok, next day they die,
I'm guessing they are responsible for lots of the issues people post on here though.
M
MartyR
West Midlands
  • #19
I agree they seem to be the last thing anything thinks of. That being said it may not be the battery, could be a wet alternator. I did notice in the battery box the main pos cable that I believe feeds to the alternator looks like it has some damage which I didn’t notice before.
My main feeling it’s the battery was the battery warning light was coming intermittently after about 10 mins the radio died, the ac cut out and then the gauges lit up.
A colleague did say it could be water in the fuse box or a earthing fault.
Either way it’s multi meter time this weekend. I’m started to wonder why I bought this car ;)
joderest
ML270 2003
have you managed to resolve this issue.
