th3h1ghlander
- Mar 23, 2016
- Location
- Wendover
- CLS 350cdi (C218) 2012 / OM642
That does help. Always useful to know things up front - like the fuel pipes being in the way of the bolts.
Is all that clear fuel piping nylon? I've used nylon air line before to replace rotten fuel pipes between tanks and engines, though it's bit of a pain to get it hot enough to go over the fitting barbs.
My pipes were in the way but then again I did it without taking off the rad fan which left me with less space to manoeuvre. The issue was just getting the bolt situated, other people don’t seem to have had the issue so perhaps my pipe position isn’t as optimal as others, luckily I had a smaller tipped socket as the full size one wouldn’t go (and as a result the bigger one dropped into the engine pan DOH, and the wheel bolts were rusted on so I couldn’t take the wheel off to get at the pan haha)
The pipes are translucent, I assume nylon, I returned the ones I didn’t use so I didn’t encounter issues installing them, I just put new o-rings on the existing pipe connectors.
