The drivers window on my 2003 ML270 has stopped working. The motor is still going and I can pull the window up and down with my hand.
I removed the door liner / card and had a look in. The big semi-circular cog is still moving back and forward or around to be more precise, but it doesn't seem to be bringing the attached arm with it. The arm is still attached at the pivot point, but does not follow with the cog.
I assumed that there would have been a rivet or bolt of some sort between the arm and cog to carry the arm around, but I cannot see where it would go.
To top it off, the SRS light is now on. It think this is because I unpluged the door airbag when I was taking the soundproofing off to have a look in, can this be reset without a dealer plug-in
Can anyone advise me on these?
