Ml320 auto gearbox problem
Dek94
New Registration
Ml320
Hi i have an ml320 year 2000 and when I put the stick in d and drive the car won't go out of 1st I have tried the transition fluid no joy what could it be I only have this car and it is costing me stupid money on fuel driving at 3000 rpm at 30mph help me
AMGeed
Poole, Dorset
S204 C180K
Welcome to the forum
When you say you have "tried the transmission fluid" do you mean you have checked the level at 80c, engine running and in park with the correct transmission dipstick? Incorrect ATF levels need to be ruled out first.
You need proper diagnosis, preferrably at a MB independant workshop with Star (MB diagnostics)
That should confirm you probably need a new electroplate/speed sensor in the gearbox.
Star will read the gearbox ECU and display fault codes meaning easy diagnosis.
I believe the cost is around £400 including parts, fresh ATF, filter and labour. Taking it to a main dealer will cost considerably more.
What is your location so someone may be able to advise a decent indy nearby?
