ML320 Full Service Question ( 2000 yom )
Discussion in 'Engine, Drivetrain, Fuel and Exhaust' started by voguev8, Dec 19, 2012.
  1. voguev8
    voguev8 New Member
    7
    Mar 22, 2011
    Dorset
    Your Mercedes:
    ml 270 cdi (W163)
    Owned my ML for 6 months now, done 5000 miles and apart from bouncing drivers door lock (Managed to do myself after reading a excellent write up on a Usa forum), has been trouble free and a great drive.
    I changed the oil and air filter when I first got it, just to be safe as service history was a bit patchy.
    I plan to keep the ML and was thinking about doing a full service in the spring.
    I will change the oil again etc, but was thinking about things like plugs/fuel filter/diff/axle oils/ auto trans/brake fluid and maybe drain and refill cooling system!.
    Any pointers at what I should be doing, bearing in mind I dont know whats been done in the past, mileage is 104K.
  2. Steve@Avantgarde
    Steve@Avantgarde Forum Supporter Authorised Forum Supporter
    6,825
    1,003
    Dec 8, 2009
    Bristol/Somerset
    Your Mercedes:
    C220CDI AMG Line Premium, SLR McLaren Roadster, SL55 & C32AMG
    Its all easy to do if you have the right tools to do it!
    You will need a form of pump to pump the oil back into the diff, gearbox oil is filled through the dipsstick.
Share This Page
