ajlsl600
- Nov 18, 2013
- Location
- france
- clk3202001,sl6002003 with everything regrettably sold ,A class 170cdi auto. NG/TF1800 ML250
yest i changed the ml oil and filter. have to pump it out . ok done that , changed filter .book says oil and filter fill 6.5 lt. i am a bit fussy about this so spent a good 15 min trying to pump all the old oil out . i added 4.5 lt started turned off .topped oil to 4mm below top mark. 5.6 lt .so 1st issue try as best, cant avoid mixing old with new in the region of a lt. I DONT LIKE THAT.car was level. next getting all the dirty oil out of the pump pipework , ie hanging the pump in a tree above drain tray to get it all out. next morning check oil before start. buxxxr me its well over the top plastic section ,I DONT LIKE THAT EITHER ! DONT WANT TO f/up the CAT out with pump again drain to 8mm below,. this involves removing just over half lt it i have made a guess that the filter draining down will put the level to just below the top level when checked in the ami am guessing but i doubt i got any more than 6 lt in to get to the level its now at. all this messing around so some bean counter can tell his boss they found a way to save 10 cents a car....i like to drain all my warm oil out ,not leave half lt plus inside ..why cant we just have a damn sump plug
next ballache pumping oil into gearbox and that little tube that defines the correct ,warm level someone explain to me, why the fill amoUnt could not be predetermined at the factory and a normal fill plug installed is all this faffing around really just to save 10 cents on providing a fill plug .and what is so different today that means a 50 yr old simple method needs to be messed with now.
i know i am old and a little inclined to be grumpy ,but REALLY ?
