Moonroof problem
Digger25
03 e320
Hi all I am new here
I have problem with the moonroof on my 03 reg e320 I wonder if anyone can help
Right well I have not had the moonroof open for ages it’s not something I use
Very often
Anyway I dicided to open it the other day so I pressed the button the internal flap opened but the roof was a bit sticky so I freed it up with some wd40 and put some grecce in the track and it’s now working fine but the internal flap won’t close
I press the button but nothing happens can anyone help please
Many thanks Jason
Linuus
crawley
w210 wagon
Try closing it 1st manually with the special tool that normally comes with the car. And then try again, also check the fuses see if they are well placed!!
D
Digger25
03 e320
Hi I just went and tried to close it manually but still the same
One thing I have noticed is when I open the door the computer says close tilt and slide roof but the roof is closed
Uncle Benz
West Sussex
Mainly Mercedes
Have you tried programming the end stops? Open fully, then hold the button further open for ten seconds. Fully close and repeat the holding thing. Do the same at fully tilted.
D
Digger25
03 e320
Hi yes I have tried that and no different
Yugguy
Rugby, UK
C220CDI W204 Elegance Comand
Why is it not a sunroof?
Naraic
2005 CL500.
Because the roof is panaramic and is one tinted sheet of glass that makes it a moonroof
What country are you in?
Moonroof is a USA thing. We have sunroofs or panoramic roofs.
keefysher
Hampshire
W166 GLE350AMG Line 3.0 2017. BMW Z3 2.8 1998.
Is Digger not a colloquialism for an Australian squaddie? Oz was approaching becoming the 53rd state of the union at one point importing those horrible shopping malls, fast food sh1te and have a nice day.
WD40 was not the best thing to spray about. Did you use a silicone grease? Is there a build up of dirt in the drain tube at the front sides that maybe preventing the wind deflector from bottoming properly
D
Digger25
03 e320
I am in the uk so ok if
my user name is digger because my initials are JCB and a JCB is a digger
D
Digger25
03 e320
And the drain rail and the slides are clear
www.ckinsurance.co.uk
