E240 Owner
- Oct 6, 2007
- Location
- Wilmslow, Cheshire
- C180 Exec Se
New to this forum, so hope I do it right... sorry if it's a long story!
My E240 Elegance, first reg July 2000 has always been maintained by Mercedes since I bought from new. No problems running, 44,770 miles done.
May 21st.: Cruising down the M6, 80 miles from home, a brief flicker of "Check oil level". Stopped at next service station for a coffee, then dipped to find oil only just wetting botom of dipstick :-( The level had been normal before setting off.
This is the first time I had ever needed to put any oil in it, but topped up with expensive synthetic anyway. (Display said add 1.5L)
While accelerating onto the motorway again there was a dull noise and I saw only smoke in the rear view mirror. There was also a marked lack of power. Not being keen on stopping on the hard shoulder I saw an exit one mile ahead so cruised gently - and smoking - down the slip road and stopped.
A call to the magic 00800 number brought an official Mercedes van & rep who hooked up the diagnostics machine and said the only thing he could see was misfiring. He said I should follow him to the main Merc dealer/workshop. I was hesitant, but he said it would be OK.
The garage called next day to say it was repaired: they had replaced the MAS, replaced oil with mineral (?) and done filter change. £600 bill and I drove away.
All seemed normal until leaving the motorway after some 60 miles. On accelerating onto roundabout exactly the same happened again: clouds of smoke and no power. Limped the short distance home and called my local Merc garage - and notified the original one in no uncertain terms!
This garage said the MAS had not been boot-strapped (?) which they did, gave it a hard road-test and gave it back to me, but kindly charged me nothing. They said I should take it away and report if any other problems arose.
I then ran only locally for about 500 miles, keeping an eagle eye on the oil state which seemed to be stable, and all seemed normal.
September 24th: Cruising down the M6, some 60 miles gone I accelerated to let a bus overtake and exactly the same happened for the third time: clouds of smoke and no power. Drove it gently into the original garage (seemed the most logical thing to do) and ranted a bit.
September 25th: garage rang to say valve stem seals are knackered and need replacement. Their explanation for loss of oil. Also #1 cylinder lack of compression and plug oiled up....
October 2nd: garage rang to say the valve stem seals change has made no difference, but removing the head on the one side has revealed deep scoring of the bore - so bad that an engine change is the only remedy.
I kept Mercedes Customer Service informed all the way through and that is how things stand today. My complaint has been made and it still "under review". Any good suggestions welcome as to how I should proceed from here - assuming Mercedes don't say they will cover it!! They expect to resolve the question next week. What the bill is up to now with the first garage, I don't yet know.....
