Smaltze
Righto, just had my first mot on my w210.
Various thing to report, unfortunately its failed.... BUT only on some pesky lamps and indicator problems.
My straight pipe exhaust (described on the advisories as 'heavily modified':lol: ) has passed. The upper cat and one of the two lower cats are empty, and i had a bit of a silent freak out when he said they do actually do an emissions test as well as smoke test. But anyway its passed with seemingly no problems, along with all the other mods like the lowering, remap, ecu shunt and my alloys with stretched tires.
Promising news all round.
Now, it has failed though, perhaps you guys can help.
Its a bunch of things, front position lamps are the wrong colour etc, the previous owner put in blue aftermarket ones which i wasnt aware is a problem.
The main problem though is the indicators on both sides are flashing very fast, a problem ive seen before, but i havn't been bothered by it and wasnt aware it was a fail. My old man had the same problem on his w211 and it's apparently a bulb.
The side repeater (which is the indicator on the wingmirror, right?) on the nearside is not working though acording to this fail report, i didn't actually realise this. the mechanics inside it have been broken for a while now too, it doesnt fold in. Is this repeater likely the cause?
Only other things are the rear nearside indicator is 'incorrect colour'.
Both my wingmirrors have rubbish cheap glass all misty, and various problems. so im tempted to see if i can get a set of entirely new wingmirrors including the fancy heated/dimming glass from a breaker, if itll fix my problem with it.
Thanks all
Thanks all
