- Mar 14, 2005
- Age
- 89
- Location
- Daventry
- 2002 SL500, 216 CL500, all fully loaded
I think before anyone ask for help and they want to try and fix it , they should at least own a small multi meter They can be purchased from £5.00 to £2000. A cheap £5.00 with a current range of 10 amp will cover most jobs on the car.
On the DC range, you can test your battery, missing voltages on relays, washer pumps and the like.
On the OHMs (continuty/ressistance) range you can test,fuses/ broken wires,relays,lamps and small motors/ pumps/switches and sender units.
On the AMPs (Current) range since the item under test has to be in serries, not so much use for the average job, but use for checking battery drain and alarms.
For all of the above I can tell you what you should be reading and how.
Malcolm
Malcolm
