Multiple misfires on cl500 w215
Andrew jones
Cl500 w215
Can any body help? Keep getting check engine and multiple misfires when driving after approx 300yrds
I have replaced catalytic converters,
Maf sensor
All spark plugs
All coil packs
Ecu has been checked and passed no faults
Fuel pressure checked , ok 4 bar constant .
I can clear the fault codes on star and engine runs fine but when driven it goes into limp mode with check engine light on
Any advise would be great as I’m out of ideas
Thanks all
Andy
Craiglxviii
Cambs UK
Has the car been put on Star so it’s diagnostic codes can be read?
A
Andrew jones
Cl500 w215
Yes I have star/century/das
Have you changed the ignition leads?
Cole@MBS
www.mbssouthampton.co.uk
They suffer from water in the fuel rail due to it being a closed rail. Remove and wash out the rail with brake cleaner.........old fault but I still see it from time to time.....
A
Andrew jones
Cl500 w215
Thanks I will try that, I have tested the fuel for water etc from the fuel rail and all looked good. Got to be worth a try
Disconnect the lambdas and see if it runs ok from the map open loop. If so the the issue is fuel related.
A
Andrew jones
Cl500 w215
That's really useful ,
When you say disconnect.... Do you mean just unplug all 4 and also when you say map open loop what do you mean
Many thanks
Under normal circumstances the engine runs using feedback from the Lambda sensors to control mixture. This is called closed loop and the lambda sensors modify the base map (you see this in STAR as long term and short term fuel trim).
Removing the connection to the front lambdas means the car will default to the base map as it no longer has feedback on mixture. This called open loop.
Most ECUs run open loop on cold start, for a period after warm start and on wide open throttle.
The rear lamdas only monitor the health of the cats and play no part in fuel management.
A
Andrew jones
Cl500 w215
Thank you very much I will let you know how it goes
One word of warning. Don't run without lambdas for any longer than needed as closed loop prevents the cats from overheating and becoming damaged by excess fuel.
A
Andrew jones
Cl500 w215
Understood thank you
A
Andrew jones
Cl500 w215
Update,
Ok so I cleaned all the injector rail out and tested fuel injectors
Problem remains
I also tried running in open loop , problem still occurred
Grrrrrrrr!,,
Craiglxviii
Cambs UK
Andrew, where do you live please?
A
Andrew jones
Cl500 w215
  • #17
Sandwich, Kent ( NR Dover )
Compression test? engine in good health
A
Andrew jones
Cl500 w215
  • #19
Hi yes , once fault codes are cleared engine runs smooth and strong - for about 300 metres , then check engine and limp mode
Cam/Crank sensor? What is the rev counter doing whilst it is misfiring?
