Mystery Rad has been solved !
S.Speed
Lancashire
Older Citroen Now :-(
Hi All,
I have finally managed to find out what the Mystery Radiator on my C270 CDI is for.
A very, very big thank you to Ian B Walker off this forum for giving such invaluable help to me with this.
I went to his place of works today and had a long and very interesting chat with him over a cup of coffee.
Ian Restores / repairs Older mercs (and newer ones)..
Back to the subject of the mystery Rad..
He had a Partially dismantled C270 CDI in his workshop and so he could actually show me where the pipes and stuff went from the secondary Rad..
It is basically a Fuel Cooler / heater..
The pipes contain Engine coolant which goes via the pipes you can see to a sort of heat exchanger that cools or heats the fuel (depending on the climate the car is in.
I then asked him about the dreaded V A L E O question..
I am very chuffed to learn that my car does NOT have a radiator that is shared with the transmission fluid..
My car has a Radiator that is Engine coolant and nothing else..
Again Ian demonstrated this on the partially dismantled one he is working on..
I cant thank him enough for the time and patience he showed to my 101 questions.
His enthusiasm and knowledge are quite something to behold.
A very, very big thank you Ian..
My best regards,
Rory
Cheshire, UK
Thanks - I too thought it had some connection with the fuel/induction system.
But, if the main radiator doesn't cool the ATF - where is the ATF cooler???
Ian B Walker
Lancashire
300td
The atf cooler is integrated with the engine oil cooler situated behind the oil filter. Its the aluminium finned block.
S.Speed
S.Speed
Lancashire
Nice one Ian..
Thanks for your input..
I doubt I could have explained it as well as you have done.
NJones59
Kent
E350CDI Avantgarde
So, excuse my ignorance, but are all C270CDIs clear of the Valeo problem or should I still be having sleepless nights :)
S.Speed
S.Speed
Lancashire
NJones59..
I personally cannot say but I strongly suggest you PM Ian B Walker and ask this question..
I am reasonably certain he told me its not a "C" Class problem..
But please dont hold me to that..
