Navigation Device Unavailable
izy_wizy
Surrey/London Border
E320 CDI 2004
!!! I have an 04 E320 CDI and have been enjoying using the sat nav (except when it take s you the long way!). At the weekend i tried using it again and all i got was a the following message displayed on the command screen, 'Navigation Device Unavailable' :evil:
I have looked at the disc reader in the back and pressed eject numerous times with different amounts of pressure on the eject button :lol: but the disc doesn't even come out. Then i thought may be somone has nicked it so i tried putting another disk in it but it would not go in!!
Anyone with any ideas? Is there an overide button or pin hole to eject the cd? Can it be un plugged or re-booted?
All help greatly appreciated!! :p
I
izy_wizy
E320 CDI 2004
Tried to stick my hand behind it but it won't fit!! will have to unbolt it and pull it out! Will let u know.
Best to pull the Comand fuse and re fit, and it should re set
I
izy_wizy
E320 CDI 2004
ok. There is a bank of fuses by the reader and the fuses are numbered but can't find the diagram!! i supose its in the manual at home and i'm at work!! Anyone know where i can look at one on the net?
The fuse list is often in with the tool kit or folded inside one of the boxes. You have 4 fuse boxes on that car at least
outsmartsmart
Warwickshire
1995 A124 E320 Sportline
The fuse diagram is tucked away in the fusebox at end of the dashboard, hard to see as well. Open the door and pull the panel off the end of the dashboard that sits flush to the door when closed. You have to give it a firm tug and it distorts a lot before popping off, making you think you should stop pulling!!!
As you look at the bank of fuses/relays to the LHS neatly folded and in a little holder is the fuse diagram (it measures about 2.5" x1" and is vertical and you are looking at the thin folded edge, hence hard to see). If you want me to check the fuse mine is in the car here at work
Be nice if your car is the same build year, there are many changes in the fuse box layouts
outsmartsmart
Warwickshire
Mine is same year and model but I am well aware that even this is no guarantee its the same:rolleyes:
I
izy_wizy
E320 CDI 2004
Just got round to pulling off the end cover for the dash and theres no fuses inside!!!
There is a bank of fuses under the bonnet and in the boot!!
outsmartsmart
Warwickshire
Well that makes my job redundant then in checking on mine. Mine is a 2004 E320 CDi Avantgarde by the way........:confused:
I
izy_wizy
E320 CDI 2004
Mines a 04 E320 Avantgarde too!! When you take the cover off can you see the fuses straight away or are they behinf something?:shock::evil::shock:
outsmartsmart
Warwickshire
No, fuses immediately visible once panel off.
Daft question maybe but it is a RHD car and you're taking the drivers end panel off?
I
izy_wizy
E320 CDI 2004
its a rhd but i am taking of passengers side pannel. Will look again lol. and look behind into the dash! thanks
So that we speak the same language I try to refer things to passenger side and drivers side, and this takes away the LHD / RHD mix ups
I
izy_wizy
E320 CDI 2004
Right i'm starting to get annoyed now!!!!!!!!!!
I have taken off the passenger side pannel for the end of the dash and there are no fuses there. There is a black plastic moulding with nothing behind it! If i get a chance later i'm gonna un bolt the sat nav reader and pull the plugs and put them back in unless anyone else has any ideas!!
Let me have the next 3 numbers after 211 and I will look it up
I thought the fues box was on the drivers side??
You have 7 fuse boxes on your car
F28 is the one for the navigation rated at 30 amp, it is in the fuse compartment drivers side
Tel: 020 8863 9233
