Need HELP with Whirring noise at low revs (C250 CDI W204)
Rudi Vid
2011 C250 CDI (W204 Post Facelift)
Hi Guys,
First time posting in a forum ever, so apologies if any of my forum etiquette is rusty!
Basically I'm having a complete nightmare with my 2011 C250 CDI (automatic & 60,000 miles on the clock) and I cannot get to the bottom of the problem. As the title says, I'm experiencing a whirring/whistling noise at low revs (between 500 - 2200) regardless of whether the car is in neutral or in drive, it almost sounds like a mixture between a kettle boiling and an electric drill. The noise follows the RPM up and down as you accelerate and decelerate before dying off. I have seen other posts with similar issues but nothing exactly like this so I decided to create my own to get the best help possible.
There is absolutely no other ill affects caused by this other than the massively irritating noise itself, the car is running perfectly, however I suspect this noise is an indicator that something is about to give so I am very keen to get a head of this and get it sorted.
I have already had the car at 3 separate mechanics all of which have been equally useless at firstly hearing or identifying the noise and secondly once they've been spoon fed on where it is and what i think it may be they have came up with fixes which have not worked.
Within the last 2 weeks this is what has been checked/done on the car:
  • New Idler Pulley
  • New Water Pump
  • Oil & filter Change
  • Transmission Fluid & filter change
  • Hoses checked for leaks (none found)
The power steering fluid is full so it's definitely not that, as steering has 0 difference on the noise anyway. The noise does seem more prominent or noticeable when the engine is warm as well if that helps anyone identify anything, and the whirring is not constant, again only happens when you rev in neutral or in gear between 500 - 2500 rpm.
My gut tells me the alternator is on its way out but the fact that I'm not suffering from any false starts, miss fires and electric issues of any kind sort of makes me question this.
If anyone has experienced this or has any suggestions or knowledge they could share I would be greatly, greatly appreciate it. I have only bought the car 1 month ago and this has really taken the shine off owning it. Thanks in advance guys.
Westheath
South London
First basic test is to remove the Auxiliary Belt and listen for the noise.
If the noise persists its going to be on the engine its self,
check the manifold around the turbo
as a loose/cracked/leaking manifold can produce strange noises
especially when the boost is coming on and at full charge pressure.
Also check the timing chain.
Could speculate more but without a sound track to listen too................
BTW: Welcome to the forum.
R
Rudi Vid
Thanks Westheath, neither of these things have be mentioned to be yet so will get looling at these straight away!
R
Rudi Vid
Sorry i should have put this up along with the main post nut didnt have time to post it, here is a clip of the sound, you can hear it best in thr first 6 seconds of the video when the revs go down.
Westheath
South London
It might be better to get some one record the sound under the bonnet :)
but.........
I can hear a noise early on in the video, is that from a cold start or when the engines hot ?
R
Rudi Vid
Yeah I'll get a recording with the bonnet up today for sure. This was taken when the engine was warmed up fully to 90 degrees. Its more noticable once it is at this temp than at a cold start.
