Need info on Camber Bolts - Malcolm?
jberks
Probably one for the oracle - though if anyone else has anything it would be greatly appreciated too....
I've booked into a tyre place I know of old. He's done me a great deal on the tyres, and he does 4 wheel alignment so hopefully I can get it all sorted in one shot.
My only concern is that he seemed a bit vague when I started discussing adjusting the rear on the 211, camber bolts etc. I know him from years ago and trust him implicitly but I assume he's not done a 211 rear setup before -
Is there an MB sheet on the subject I could give him to point him in the right direction?
thanks guys.
Do you have standard suspension
I need the next 3 vin numbers please
jberks
jberks
Thanks Malcolm.
I believe its the sports suspension that they insisted went with 17" wheels but I'm not certain.
The VIN is WDB2110162A629149
kth286
E320 Coupe 95
rear camber would not be adjustable only rear toe.
front camber and castor and toe is adjustable.
All ready for you..just need an email address
Dazzler
Haverhill, Suffolk
W211 E320 CDi Estate 05
Tony at WheelsInMotion will still help you out and give pointers if you ask him nicely;)
He keeps the bolts in stock too, and is a very nice chap.
jberks
jberks
Well all done,
I don't know what they did - may just have been standard tracking but it is noticably better. No longer tramlines and the wheel points in the right direction. I'll wait and see how the tyres wear.
Well all done,
I will check the post in 2 years time then :D:D
seabadger
Borsetshire
W218/2013/CLS 250CDi
Camber Bolts
Well all done,
I was interested to read your post on Camber bolts. I cured my pulling to the left, asymetric tyre wear, and improved the ride considerably when I fitted camber bolts to my W211. No more plugging into potholes and the steering much lighter. I had the bigger 17" wheels like you.
The cause I put down to excessive spring wear which made the car low on the road and the wheels lean in. The back end was suffering the same probs when I got shut but no correction kit available. Tyres wearing on the inner edge. Budget tyres okay till 20k then suddenly they went on the inside egdes - frighteningly fast! At the end I rode Michelins and got in excess of 30k.
It might have been possible to change the spacers on the spring ends but that seemed a mighty task and probably better to buy and fit new springs if dismantling the suspension. Camber bolts for the front cost me £25 and I fitted and retracked the car myself with a tape measure giving perfect results.
Its not like you to not know what they did? So I wait to hear the full report.
The CLS has air suspension and alters the ride height depending on setting. I notice I am getting a front inside edge going on a new Michelin Pilot Sport 2 (nearside) after 18k whereas there's a good 5mm tread across the full face of the tyre. I'm putting that down to a querk of the suspension which covers a big range and as a consequence I'm driving less on the ground hogging Sport 2 setting. Can't wear the back tyres out though - I bought 4 Michelin PS2 on a discount voucher from Costco fitting only two nearside at the time. A year on I still have a 275/35 18YR up in the roof of the garage.
Best regards
Seabadger
lutters
East Kent
2004 W211 320cdi
Gentlemen,
I am just about to hunt for a new set of tyres for my 2004 W211 320cdi elegance on 225zx55x16. I was surprised to see how fast the edges went (almost as if the tyres were under inflated). Having said that I find I have had some 24k miles out of them so shouldn't complain as there is well above minimum tread in the centre of the continentals. I have noticed that the wheels tend to follow road imperfections now so wonder if I should have a suspension check and 4 wheel alignment by my indie? Any one had good quotes on new tyres?
Best regards,
John
jberks
jberks
Gentlemen,
Best regards,
John
Yes - always worth getting it checked/adjusted. If its tramlining on 225/55's then its almost certainly out. Thats probably why the edges went. It just takes a pot hole and away it goes.
As for prices - Costco for Michelin. Otherwise I normally check blackcircles and mytyres online (kwikfit too) and then have a ring round. The last 2 were the same price from this local guy as the best internet price so sometimes shopping around the small local people can pay dividends.
