Need new MAF!
m3gt2
Leicestershire
'68 E220 estate Premium Plus, Command Online with Virtual Cockpit, soft close doors and full ceramic
Just had this diagnosed as faulty. I seem to remember reading somewhere that they are made by Bosch and if you get just the sensor its about £50/60 not the £200+ at Mercedes, is this correct and if so what are the part numbers please? Or am I best just going down the Merc route? Cheers
Pathfinder
Gourock
Input your reg No. into Eurocarparts website. Select the Bosch option. Check the price, enter the discount code before buying. Click.
If the actual sensor part has a Bosch part number then this can be bought from any Bosch service center for about £70,no part number then only complete and from ECP in the above post
AdamG
Bromley, Kent
S320CDI (2003)
The maf in the facelift w220 s320cdi OM648 engine is the one that comes complete with the tube only and is more expensive.
I looked for ages to find a genuine bosch insert but to no avail.
What makes you believe the maf has failed? Have you done the test on Star?
Also check the wiring to the maf plug as this can fatigue.
Adam
m3gt2
Leicestershire
Got incorrect readings when it went on Star but didnt have time to leave it to have wiring checked etc so swapped it with my other car and had no problems since, have had it plugged on Star again as I had no problems in a couple of weeks and with the other MAF the readings are correct.
Very seldom that STAR shows anything on the MAF
m3gt2
Leicestershire
The independent said you can take live data with Star, not that it was showing a fault code.
Yes true, but also hard to work out
m3gt2
Leicestershire
You can measure the voltage on pin 5 the output pin,,, what is the problem on the car
m3gt2
Leicestershire
It seemed a little lumpy on idle and gentle acceleration, seemed to hold on to gears to long before kicking down and sometimes went into limp mode. It also came up showing codes for the inlet manifold flaps that was a faulty motor, which was changed, and EGR fault which was fine when checked. The independent thought that code could be a knock on result of the other problems. The other car i put the 'faulty' MAF on does now seem to hold on to gears to long but no other problems with that.
I will try and find the voltage chart for pin5
The link between the MAF and the gearbox is purely engine output related, id the engine power is down the gearbox does not know what to do and often just locks up or holds gears for too long
m3gt2
Leicestershire
Thanks that would be great!
