Need to get into boot (98'c230)
LarryLoafer
kent
Hi all, great site.
Dilemma, flat battery, as i've always used the remote key fob to open boot, i've found the boot lock corroded so the key wont go in (have loaded with WD), i wonder if i can put a 12v supply to somewhere under the bonnet or through the cig lighter to power the car then pull boot switch on console, i had the boot open yesterday and disconnected the battery ready for charging today, shut the boot but it some how locked it's self?
any advice?
LL
Yes a small12 volt power supply can run the pump to open the boot from the cigar lighter with the key turned to 1 or 2 (if it will) other than that you can put 12v onto the thick lead on the starter motor, you could also have a terminal block under the bonnet, thats a large red and black terminal block.
Any of the above will run the pump so that you can unlock the boot
L
LarryLoafer
kent
Thanks Malcolm
Many thanks Malcolm,
I cant get the key to 1 or 2, I thought there might be a terminal block but cant find it?, i just went to Maplins for a ciggy charger & ran it off my van but no joy..maybe because the battery is disconnected?
regards
LL
C220GJS
Shotts, Scotland.
1995 W202 C220 Elegance
Larry your cig lighter charger won't work unless you can turn the ignition switch to 1 or 2.
Have as look in the Ecu compartment at the passenger side rear of the engine bay, there may be a small rectangular black box about 3"x 2"with a hinged lid.Inside there are three terminals all of which are +ve and if you connect leads from a battery here and to a good earth point you should be able to pop your locks using the dash switch whether your battery is connected or not.
L
LarryLoafer
kent
C220GJS/Television/Malcolm
EURIKA!!!!!!!!!!!!!!!
You fella's are Heaven ****** sent, you've saved me a small fortune
Small black box and a convienient earth just underneath & up she popped
I cant thank you fella's enough, should you pass by Bromley Kent in the furture the drinks are on me!
all the best
LL
all the best
LL
No,we have our feet on the ground and just love to help out
