New battery runs completely flat.
Paul Winnett
W203 C 270 2004 diesel
I have a C-Class 270 W203. The battery required replacement and a new battery purchased and fitted by myself. After running the car for about 8 miles I parked up. Returned an hour later and the battery was completely flat. Assuming the new battery was at fault, I purchased a second, fitted it and after a short run in the car, the battery went completely dead.
It seems that although the car's electrics seem fine when running and is charging, after half-an-hour the battery dies.
Any ideas?
Hello and welcome
Faulty diode pack on the alternator can cause high battery
P
Paul Winnett
Even while it's parked?
davemercedes
Glos
Funny timing for your post. I bought a Mercedes battery for my S203 from MB Avonmouth 3 - 4 years ago but the car has been standing outside in the cold and wet for weeks while we're locked down... I had to take swmbo out (we had run out of milk!) and turned the key... the charging light went out and "yeeuch" it was dead as a dodo...
Cutting it short, I started the car with my jump starter then afterwards. I left on charge pn my 12v automatic charger. Five hours later when I checked, it was fully charged (well, at least it started on the first turn as usual. We've had to go out twice since and the cold start result has been the same - i.e.: one turn and it starts.
MB batteries seem to justify their price (and I know... other brands are available!)...
Tony Dyson
God's Country
2014 C 220 CDI W204 OM 651
Especially when parked
If one or more diodes fail in the alternator the failed units will allow a back feed from the battery to the alternator and it will discharge the battery overnight, you may have flashing lights while the car is running indicating failed alternator diodes.
I had it on the 911, it was a random fault as it depended where the alternator stopped as to whether it would discharge or not.
Tony Dyson
God's Country
It's one of the pitfalls of using an alternator to provide a DC Voltage, it wouldn't have done any of the consumers on the car any good either providing them a DC Voltage peppered with an AC Component.
star
Reading
Smart + others :)
That’s a big battery drain, I would suspect the block/aux heater.
sonic
Staffordshire
E350CDI, SLC250d, FJR 1300
For a battery to go flat in an hour or so requires a massive drain, possible 10 to 20 amps.
Did the battery connections spark when you connected them to the battery?
You need to meter the battery on & off charge. You either have a short somewhere, or the alternator is not charging.
P
Paul Winnett
Thanks to those that have made suggestions.
SONIC, yes the battery sparked when I reconnected it which would suggest a current drain, so possibly a short somewhere. A fully-charged 90-amp battery draining down in less than an hour seems odd considering there is no indication of a major short circuit. Could it be the regulator?
Flyinspanner
Ruislip
So it has a 90+ amp drain!
Hasn’t blown fuses so suspect battery feed.
The battery ‘controller’ (if fitted to your model)?
That’s massive, it will be a short, check you haven’t pinched a cable.
Check for chaffed cables, loose cables, any that run near rotating parts. (Belts/pulley etc)
that will also generate a lot of heat! :eek: Look for witness heat/scorch/marks
P
Paul Winnett
Thanks, I'll check for scorch marks.
