New Car High Beam Question?
Solarwinds
Arundel
W212 E350CDI
Just picked up my new to me E350cdi 2011, loving it but nearing home it was getting dark and though the headlights are great I went to put on the high beam by pushing the stalk as usual and nothing happened?...IE I didn't see the blue light you would normally see on the dash and nothing showed on the darkening road ahead. When I pull the stalk towards me, like if you were going to flash someone (!) it comes on as normal.
I have this option
608 AUTOMATIC HIGH BEAM SWITCH (IHC)
But even with that presume you should be able to manually switch on the high beam?
EmilysDad
Bury Lancs
ML350
I have this option
switch your lights switch to ON rather than AUTO & see if that works for you. Do you not get a greyed out main beam icon when you push the stalk when in AUTO?
My 14 plate ML needs to be doing around 35mph for the auto headlights to come on
Srdl
Hampshire
GLC43 AMG 2018 (X253)
^ exactly this. Just remember to turn off the lights if you move the switch from “Auto”!
s5tuart
2003 R230 SL350
My auto high beam only works above a certain speed ( no idea what ) and works on the lights Auto setting on the switch.
Dean Fletcher
Penrith, Cumbria
Mercedes S63 AMG
Auto lights are ok until you go round a corner and they automatically dip and your not expecting it :p:p
Timeandleisure
London
SL500 2003 R230, E400d 4MATIC Coupe 2021
As EmilysDad says.... your high beams may always be 'on' (depending on model), when in the 'Auto' position, so you need to switch to a manual setting to achieve high beam to order...
malcolm E53 AMG
I think my high beam assist has worked once in Auto in the 7 years I’ve owned my 12 plate E350cdi and I suspect there is an issue with the software MY11/12. Everything works fine other than this in Manual or Auto mode
rorywquin
North Yorkshire
An old B-Class.
Mine have never been out of Auto mode in 5.5. years of owning the car & I’ve never been flashed by an oncoming car. I find them amazing.
EmilysDad
Bury Lancs
ML350
My only little gripe with them is the min speed the car has to be travelling. I know that dipped beam is generally enough to see where you're going, but main beam would be better. On some little B roads, c35mph is too fast
AMGeed
Poole, Dorset
1998/2001 W210 E280 x2 SOLD 2004 W211 E55 SOLD, 2014 E63 Biturbo SOLD .S204 C180K
Select "Auto" on the light switch, then push the stalk forward to the high beam position. You should see the letter "A" in the cluster.
The car will now automatically dip the headlights when approaching another car either from behind or one coming towards you, Once its safe to do so, the lights automatically go back to full headlights (unless in a built up area with street lighting) You don't need to touch the stalk again.
They are called intelligent lights for nothing. A great system, especially the cornering lights.
The above works for option 628 IHC+ but should also work for Option 608
Solarwinds
Solarwinds
Arundel
W212 E350CDI
Yes all correct as if by magic I turned the A off and had my high beam back, also disabled the intelligent smart option in the cluster menu and then back to Auto all good. Just discovered the E/S/M button on the way home!...happy days!
AMGeed
Poole, Dorset
you had it to start with .... you just didn't know where it was
why .... :oops:
I would also question why you would disable a system that thinks for you and dips the lights when necessary.
It's a brilliant system (pun intended)
V6Matty
Newark, Nottinghamshire
The ILS system is great, but the prefacelift cars has headlight assist which in my opinion isn’t that great, I can usually react faster to changing from low and high beam quicker than it can. That’s said it’s likely they just need getting used to,
Rotorhead500
Very South Devon
Used to have a C63...
I'd agree. On roads I know, especially the bendier numbers down here, I react much quicker than last two cars, and can anticipate better than the cars' systems.
Recent years has also seen me getting blinded far more frequently by oncoming traffic, most with uber bright LED or lasery type lights - I'm certain they haven't all disabled the auto main beam shenanigans!
I’m finding similar, being blinded by badly aligned bleeding awful lights is way more common than it used to be. Being in the SLK only makes it worse unfortunately :(
