New member / First Mercedes Question
Discussion in 'Electrics, Vacuum, Ignition and ECU' started by salixarbour, May 15, 2011.
  1. salixarbour
    salixarbour New Member
    3
    May 15, 2011
    Cheshire, UK
    Your Mercedes:
    C220 cdi elegance
    Hello to all.
    I have just been to see, and test drive, my first Mercedes today!
    It was a C220 cdi Estate.
    The car seems about as genuine as you can expect, and drove beautifully.
    However, it did have a very noticable 'flat-spot' when trying to accelerate,
    particularly whilst in 2nd gear. It took far too long to reach 3000rpm, and once there, wouldn't got beyond that rpm. It was the same for all gears, but was much more pronounced in 2nd gear.
    I'm baffled by this. Could it be a limiter setting, or cruise control problem,
    or even worse, an ECU problem?
    Hopefully, someone can help to clear this one up for me. :)
    Many thanks in advance.
    Alan, in Cheshire.
  2. mikestrivens
    mikestrivens Senior Member
    2,715
    146
    Nov 21, 2008
    Stockport
    Your Mercedes:
    I'd try another one, or ten, to see if they are the same. Sounds like a walkaway job to me.
  3. OP
    salixarbour
    3
    May 15, 2011
    Cheshire, UK
    Your Mercedes:
    C220 cdi elegance
    Thanks, Mike.
    Very much noted, and appreciated.
    I shall keep on looking.
    Regards.
    Alan.
  4. television
    television Always remembered RIP
    164,074
    309
    Your Mercedes:
    Welcome Alan to the forum,, that car was not OK probably needed a new MAF,
  5. mikestrivens
    2,715
    146
    Nov 21, 2008
    Stockport
    Your Mercedes:
    Oh and hello and welcome !!
  6. OP
    salixarbour
    3
    May 15, 2011
    Cheshire, UK
    Your Mercedes:
    C220 cdi elegance
    Thanks, Malcolm / Mike.
    After my initial posting, I searched the forum and guessed it might indeed be
    the MAF sensor, or possibly a sticking EGR valve.
    I've previously owned two other diesel cars (currently a Kangoo 1.5 DCi), and have indeed experienced the dreaded MAF problem on my first diesel car, and the EGR valve problem on my Kangoo. The AA identified the Kangoo's problem (about a year ago) and it has run beautifully ever since changing the EGR valve.
    You do wonder though why on earth modern diesel cars seem to be so vulnerable and dependent on such simple delicate components, and how a dealer has the nerve to try to sell a faulty £9000+ car?
    Thanks again for your advice.
    Regards.
    Alan.
  7. mikestrivens
    2,715
    146
    Nov 21, 2008
    Stockport
    Your Mercedes:
Share This Page
