simonmc
Hi, there all.
I have a few small problems with my ebay bargain 1886 190. I knew of several of the faults already and most of these will be solved by a good service. However the seems to be a leak in the vacuum system wich means the central locking, headlight adjust, and the vaccum gauge do not work. However the pump under seat seems to work. Also the tacho does not work. All of the faults are of a non critical nature but are annoying as i would like to get them working. I have already found several disconnected pipes and reconnected them.
Is the vacuum gauge electrical or mechanical? And how do you remove the instrument cluster?
Also are the small white/yellow cylinders one way valves? and if so do the come apart? (I work in a rubber gasket factory, so i may be able to replace any seals)
Thanks for any help
simonmc
Thanks for any help
simonmc
