New member needing vital info on 260 E 1986
Status
Not open for further replies.
Donny
Leicestershire
I have been having trouble with my front passenger and rear offside windows - both are not working. I have checked the fuse but that seems fine, any idea's of how to rectify this problem?
Thanks in advance.
landover
Banned
Scotland
www.landrovertd.com
First check there is power at the switch . If you have power change over the switches from the windows that do work . If that does not work check for power at the motor in the door.
If you have no power here it might be a broken wire between the pillar and the door .
talbir
London
This is most definitely a fuse or relay problem, as the windows are paired front offside/rear nrside and front nrside/rear offside.
You say the fuse looks fine - have you actually removed and replaced it ? The fuses on the older Mercs are appaling and can have hairline cracks - so they appear to be fine but indeed are shot. Sometime they corrode or burn at the point where they clip onto the contact, so you can never see it.
I would definitely reccomend changing the fuse and then go from there.
There is also a relay for each pair of windows, standard SPDT relay, in the fusebox.
Mikesmerc
Co.Cork IRL
2001 CL500,1990 560SEC, 1988 230E, 1982 250, 1979 280CE, 1977 200D, 1972 350 SL, 1965 220S Fintail
Same problem with my 88 230E at the moment. Took apart the rear motor/drive and found that the worm drive out of the motor was completely seized, so much so that the worm had disentegrated. Motor was fine just the worm seized. Idleness is worse than over use.
Regards
Mike
Status
