New spheres but prob. Not solved. 97.e300td. Est.
HERBIEMERCMAN
PRESTON, LANCS.
97. E300.TD. 7 SEAT.ELEGANCE. EST.TOYOTA SUPRA MK4. RS. VAUX. CORSA.GLS AUTO. SPORT.
hi everyone, just got car back from my local garage, new spheres fitted, suspension still very bumpy and self levelling still does not work, loaded rear of car, it dropped 3 inches but would not rise up with engine running, also the 6mm pipes which deliver the fluid to the control valve was cold, prior to this when working the pipes got hot. does anyone know what they could have missed? my garage are keen but like many general garages they know a little about a lot of cars but no depth on any particular car. i am wondering now if i really needed the new spheres ? maybe the control valve was the problem or the system just needed bleeding ? herbiemercman.
See what I have
Sent 5 papers on the suspension. anything else not covered please ask and I will send it
HERBIEMERCMAN
HERBIEMERCMAN
PRESTON, LANCS.
hi malcolm, can you re send the e-mails my wife deleted them thought they were junk mail. many thanks for your help. ian. herbiemercman.
I sent 5 and she deleted them,I will have to think hard about sending more :?:
HERBIEMERCMAN
HERBIEMERCMAN
PRESTON, LANCS.
hi malcolm, please think hard! ian.
HERBIEMERCMAN
HERBIEMERCMAN
PRESTON, LANCS.
Hi malcolm, thanks for info, they are not the same as my car but the operation is the same, will let you know how i go on. Ian,.
Let me have the 3 first Vin numbers and please ask for any info on any part of it
HERBIEMERCMAN
HERBIEMERCMAN
PRESTON, LANCS.
hi malcolm, the vin is wdb210, the area of concern is the rear suspension self leveling valve, how do you bleed system after fitting new spheres and how do you set up the valve? if the car is lifted up on the kind of lifts which lift the body but leave the wheels dangling then presumably the slv valve will be closed so you cannot bleed the system. ian.
RonH
Bleeding.
To bleed the system, crack open the connection that is on the outward side of the pump (on pump in engine bay).Only open it slightly to let any air in the pump out...engine running of course.Retighten after a few seconds when fluid is seen coming out.
Was told some years ago that oil pumps are just that.....used to pump oil!. Are no good at pumping air and need bleeding to get them going.
Hope that helps.....all the best RonH.
HERBIEMERCMAN
HERBIEMERCMAN
PRESTON, LANCS.
thanks for info ronh, will try it. herbiemercman.
