new to forum
Bongo1960
2006 350sl 3.5 litre 272bhp
Hi new to forum, I have a 2006 350sl i recently changed the front discs and pads everything went well until i applied the brake
The rear pads stick on both sides and do not release the fronts are ok, This is my first mercedes never had this problem before
I thaught it was possibly the callipers but its both of them am i possibly missing something
A.J.
Norwich. UK
Hi and welcome to the forum :) Plenty of SL owners on here so help will not be far away
Hello and welcome
Replied on your other thread
SmartAmg
2011 E class coupe 350 CDI
Welcome, Bongo. :)
Bongo1960
Bongo1960
Hi Andy, I hope so cheers Nigel
00slk
Cambridgeshire UK
Hello and welcome
Might be an issue with the master cylinder?
Bongo1960
Bongo1960
Hello and welcome
I will check that out, still puzzled why the front calipers are working fine
00slk
Cambridgeshire UK
It works off a tandem cylinder where by the first section of the master cylinder operate the front brakes, more pressure on the pedal operated the rears brakes too. But I have been known to give wrong advice before :rolleyes:
Bay Leaf
Stockport
SL 350 R231 2013
Hi Mark and welcome. Has your car got an electric park brake. I'm quite new to the marque my self but I think you may have to put the rear brakes into service mode before doing any work on them if I'm not mistaken. Even if your car doesn't have this it could still be an issue with the hand brake mechanism.
BL
Bongo1960
Bongo1960
BL
Hi the park brake is manual but works on the inside of the discs on brake shoes, I dont have a problem with the park brake is just seems to be on the pads
but thanks for the reply
Bay Leaf
Stockport
SL 350 R231 2013
I wonder if it's anything to do with when you wound or compressed the pistons back forcing the fluid back to the master cylinder. There might be a check valve somewhere in the system. You could try bleeding the system and see what happens.
RC
