Darren Beckley
Hi guys and girls I’ve just picked up a c270 estate today as I’m new to Mercedes ownership is there anything I should be aware of
I had a 2004 CLK270CDI, great car almost no faults & not the one you have.This may have been asked before has anyone experienced el. Power control malfunction consult workshop PCU at the same time getting sever vibrations through the steering wheel when the car is idling as mine is doing it it’s a 53 plate c270 cdi
I’ve got it in my local independent garage here’s hoping it’s not going to be anything majorI had a 2004 CLK270CDI, great car almost no faults & not the one you have.
There was an issue with the radiator up to about 2005 on all 270 engines. Two types were fitted the German Beher which was fine. Also a French one can't remember the name, had a habit of leaking oil & water between the galleries.
So far the garage are going to replace the cam shaft sensor if that sorts the vibrations out they need to put a new alternator inI’ve got it in my local independent garage here’s hoping it’s not going to be anything major
