Dodger1855
Hi, hope someone has a fix for this issue with my 2001 SLK320.
Problem started with BAS/ASP warning light coming on when braking, it goes out when I switch off and start again. I then noticed Cruise wasn't working (it's OK if I start and run without touching brake pedal) I was then 'advised' by a following truck that none of my brake lights are working.
I went for the obvious and have fitted a new switch but this hasn't changed anything (glad they are only £14.20)
Has anybody come across this before?
Regards, Roger
Regards, Roger
