no Crankshaft/ecu communication
Discussion in 'Engine, Drivetrain, Fuel and Exhaust' started by gothic_merc, May 6, 2013.
  1. gothic_merc
    gothic_merc Active Senior Members
    114
    May 6, 2013
    Lowestoft
    Your Mercedes:
    w202 cdi estate 1999 2.2, W210 E320 CDI
    Hi. I've a w202 220cdi. Had a warm start issue. Had the crankshaft sensor replaced but star still says there's a communication issue. Would greatly appreciate any advice.
    Other code's were glow plugs and esp
  2. television
    television Always remembered RIP
    164,074
    310
    Your Mercedes:
    The CPS measures 800 to 1k ohm when good,, any chance there is a broken wire or poor connection on the CPS
  3. OP
    gothic_merc
    114
    May 6, 2013
    Lowestoft
    Your Mercedes:
    I'll check, I'm not sure where it is but will try tomorrow, thank you for your reply
  4. television
    164,074
    310
    Your Mercedes:
    It sits over the starter motor on the bell housing on the starter ring
  5. OP
    gothic_merc
    114
    May 6, 2013
    Lowestoft
    Your Mercedes:
    cool, will it require removing engine cover? I am new to mercedes as a brand and have to say I love it apart from this fault. I want to keep but cant afford repairs that dont solve the issue. once again thanks
  6. television
    164,074
    310
    Your Mercedes:
    You probably will have to remove the cover
  7. Steve@Avantgarde
    Steve@Avantgarde Forum Supporter Authorised Forum Supporter
    6,825
    1,003
    Dec 8, 2009
    Bristol/Somerset
    Your Mercedes:
    C220CDI AMG Line Premium, SLR McLaren Roadster, SL55 & C32AMG
    Are you reading the fault codes from STAR?
  8. OP
    gothic_merc
    114
    May 6, 2013
    Lowestoft
    Your Mercedes:
    yeah mate hooked it up. I cant remember exact codes but on the crankshaft sensor it wasn't showing a voltage.
  9. OP
    gothic_merc
    114
    May 6, 2013
    Lowestoft
    Your Mercedes:
    I'll check wiring tomorrow to see if there is anything obvious before taking it back to garage that replaced sensor
  10. Steve@Avantgarde
    6,825
    1,003
    Dec 8, 2009
    Bristol/Somerset
    Your Mercedes:
    Hmmm. It will lose its signal voltage if it can read the sensor. i would check the flywheel for missing/bent teeth. Wouldn't be the first time I have seen that and will produce that very fault code.
  11. OP
    gothic_merc
    114
    May 6, 2013
    Lowestoft
    Your Mercedes:
    Thanks I'll get the cover off tomorrow and have a look
  12. OP
    gothic_merc
    114
    May 6, 2013
    Lowestoft
    Your Mercedes:
    Been told garage replaced cam sensor not crankshaft sensor so will source that this week.
  13. television
    164,074
    310
    Your Mercedes:
    Yes the cam sensor hardly ever fails
  14. OP
    gothic_merc
    114
    May 6, 2013
    Lowestoft
    Your Mercedes:
    I replaced the cps yesterday and the hot start issue remains. This maybe the death of the w202. Shame as was perfect car
Share This Page
