No dash board lights
Status
Not open for further replies.
andy_k
Bexhill On Sea, East Sussex
www.ak3dgfx.com
E55 AMG
first and obvious suspect is the potentiometer that adjusts the brightness - try moving it around
second suspect is a fuse - I believe there is one on the back of the instrument panel in addition to the fuse box
third suspect is the bulbs - once again you'll need the instrument panel out to check these.
Andy
MIKE236
Sydney, Australia
W124 230TE 1988
Hi John.
I had a similar prob in my car. No dash lights at all eventhogh the headlamps and rear lights are working. I did what Andy had suggested i.e. potentiometer, fuse and bulb check. All was OK. Finally checked the main light switch (above the parking brake release handle). Fiddled with it a few times and light on dash all came on at once. The other thing you can check is whether the number plate lights are off when there are no lights on the dash. I think they are all connected together..at least that was what I observed on mine. When I did manage to get the dash lights working, the plate lights were on as usual. The prob was detected to a poor connection in the main light switch especially after switching on the front fog lamps (1 pull) and rear (2 pulls). Might be worth a try and see if that helps.
john12
Marshchapel
www.marshchapel.demon.co.uk
thanks guys
Thanks Andy Mike
I will be assaulting my instrument panel as i have to replace the speedo cable but i cant seem to find the dimmer switch if there is suppose to be one anyway thanks
John :D
andy_k
www.ak3dgfx.com
E55 AMG
if it's the same as the W124 dash - the dashboard dimmer is the same control as the reset for the trip - have you tried turning that? prhaps you've dimmed it inadvertedly whilst resetting the trip meter.
Andy
john12
Marshchapel
Yippe !!!!!! My lights work
Hi Andy
Just to say thanks mate went and did what you said and turned the trip button and guess what the dash lights came on so everything is fine Thanks again
John :D :lol: 8)
Status
