The fuse is F2f2 at 15 amp
television Always remembered RIP Joined Mar 14, 2005 Messages 164,073 Reaction score 367 Age 89 Location Daventry Your Mercedes 2002 SL500, 216 CL500, all fully loaded Dec 14, 2012 #21 The fuse is F2f2 at 15 amp
television Always remembered RIP Joined Mar 14, 2005 Messages 164,073 Reaction score 367 Age 89 Location Daventry Your Mercedes 2002 SL500, 216 CL500, all fully loaded Dec 14, 2012 #22 The fog lamps are fused via F47 relay K30. If you suspect a diode just do a reverse check with an ohm meter. That relay must have a constant voltage to stay energized across pins 1 and 2 it is not self latching or it could not be turned off
