no ignition lights, 190D
Status
Not open for further replies.
flagstaff
York
'94 E220 Cab
hi all, hope someone can help: yesterday my battery went flat, with pretty much no warning. charged her up overnight, today as good as new and starts the car no prob. but - there are no ignition lights at startup ... well, the glowplug light still works - but no other dashboard lights come on at any stage of ignition. car starts fine though, like i say. anyone any idea what could be causing this? many thanks for any tips pointers etc ...
dieseldes
Central Scotland
W203 2002 220cdi
Replace the Alternator?
or as a get you home... hit it with a hammer! sometimes works as the bushes wear to their limit and start to stick. this is once only if it works at all!
I have used this method on a couple of mercs (and other makes) I have been called out to.
Also if you have a voltmeter you should have 13.8Volts across the batterywhen the engine is running.
flagstaff
flagstaff
York
'94 E220 Cab
thanks for reply ... it seems weird though that there are no dash lights: i would have thought i'd get a warning for 'no charge' or somesuch. still, i suspect you're right, and it's time to get out my extensive range of hammers ;-)
flagstaff
flagstaff
York
'94 E220 Cab
thanks dieseldes - replaced alternator today and charging system restored... many thanks again :D
Status
