no light on speedometer on my ml 270
sheebamerc
hello
can someone help my speedometer light has gone . i have checked all fuses but nothing has blown . cant seem to find out what the problem is . does anyone have any ideas . could be the bulb but i dont know how to access this, any ideas please???. all other light are working.
thank you
dragon
Banned
Have you tried turning the switch anti-clockwise/clockwise the same switch to reset the odometer by pressing it for a few seconds.
colechelle
Resigned
two small slots at both ends on cluster, need to get two hooks and give it a good pull!!!
sheebamerc
slots
no i havent tried reseting the odometer . i will do this next . cant see the two slots . do you mean i need to move it .
Yes you do need to pull the cluster out and the lamps are replaced from the rear
dragon
Banned
Check the switch first. It a bigger job to pull out the whole instrument cluster and may even scratch the plastic front panel.
sheebamerc
slots
just had a look . i can see any hooks from the dash . the whole dash is one piece. there is nothing to pull out.
dragon
Banned
What they are saying you have to remove the whole instrument cluster off the dashboard. It a bigger job, check the switch first, the bulb may not be blown. If it blown you have no choice but to pull the whole thing out and find the bulb. If you aredgood enough you can grope around to find the bulb with the instrument cluster ajar.
To pull the cluster out you do need the 2 special hooks,, many MB dealers will pull the cluster out for you, and you can change the bulb on the spot.
There is no switch for this
sheebamerc
oh ok thanks ill try resetting the switch first
Dragon,,the dimming switch that you refer to is for all of the lamps and not just the speedo lamp.
The bulb has blown and must be replaced
colechelle
Resigned
think we are wrong Malc, looking at wis theres a cover panel has to be removed first!!
dragon
Banned
The dimmer switch is for the speedo, try this one first as it simple, if it does not work then try removing the whole lot.
I removed the whole instr cluster it a bigger job.
colechelle
Resigned
try this, might help
