dmwelch54
- Sep 7, 2016
- Location
- Ashill Norfolk
- ML 270 2001 270cdi
ML320 W164 Factory fitted Oris towbar. Using 7 pin adapter, no lights on trailer. Found 13 pin wiring, checked power pins 3 n 9 12v. Checked indicator pins with hazards on, no power on/off on indicator left/right. Most pins have a trickle voltage. Wondering if the trailer towing was enabled or possibly relay as all fuses check OK. Help? Dale
