No radio reception Command
mingblus3
Was fine last night, today just got a hissing sound. The CD player works and the sound is fine. The TV works but the sound is the hissing crackling sound again.
The only thing i did last night was to reset the blower / actuators. Now this morning my ****** radio is not working. Every day i start the car up there is a new problem.
I might as well also point out that my new navigation disc is also stuck in the head unit and it won't eject. Nor am i picking up satellites still. Are there any tips on removing the disc, though I'd ask at the same time.
Regards
Simon
Where does one start. the fact that a disc is stuck in means that the eject mechanism will have to be fixed,,it is a known fault and firms do this,,at the same time other thing could be checked.
If the sound on CD is OK then the output stages in the Comand are OK,,If the TV works but the sound is hissy then it is set for the wrong country it should be on PAL I
The radio could be a antenna amp problem
The no SATs is probably the antenna
