No Revs above 3,000
Frank Tolson
1989 W124 260E Auto Reg No. G820 JYG K E Jetronic fuel
Can someone please advise.
I'm unable to get the revs on my Mercedes over 3,000 rpm?
Details of Mercedes:
*1989 W124 260E Auto
*Bosch CIS-E (KE Jetronic) fuel injection system
*Twin fuel pumps
*2.6 S.O.H.C. 6 Cyl
Any help/adviseMadvise would be much appreciated.
davidsl500
Welcome, is this when stationery or when driving? If stationery, the engine speed is limited to 3,000 revs. If it is when driving then the car is going into Limp mode as there is a problem and the engine speed is restricted to prevent damage. Do you have any warning lights lit? Have you had the car long? Have you had any work done on it recently? Whereabouts are you?
As this is an early car you'll need a blink code reader or something that can read pre-OBD2 codes.
You may have a blocked cat (if it has one fitted).
jp williams
Wirral & Axarqia,Spain
2002 E class 2.2 cdi auto estate, Lexus GS 450h
*Twin fuel pumps
*2.6 S.O.H.C. 6 Cyl
Probably needs a new MAF.
rifiki
Worksop
CLK W209 W121190B
Had similar problem with 1986 BMW E23 would not rev and some times very rough idle. Fixed with new MAF.
David Richardson
Plymouth
W176 Blue Eff CY Sport CDI & C Class Coupe 2002 220CDI
Most likely to be a MAF or if diesel the EGR valve
star
Reading
Smart + others :)
No maf or egr on this car. Borderline if it has a cat. Are you trying to rev it in neutral of whilst driving?
John Laidlaw
Wirral
Land Rover Discovery 4
welcome- as above, and see forum moans....
McDonald
Surrey
SL500 2004
People unfamiliar with the forum may imagine that they should check next day to see if anyone responded. It's a blessing that this is such an active group, but that may come as a surprise to a first time user.
F
Frank Tolson
John Laidlaw
Wirral
Frank, reply outside the quote box please otherwise you'll lose your comments, ta!
F
Frank Tolson
F
Frank Tolson
Yes you are correct no maf, egr or cat.
Can't get over 3,000 rpm when in neutral or driving.
Any idea?
Many thanks.
star
Reading
Smart + others :)
Has it just started to act up or has something been changed? It does sound like fuel starvation tho.
When was the fuel filter last changed?
F
Frank Tolson
  • #19
F
Frank Tolson
  • #20
Thanks. Yes we think it's a fuel problem. Hope this will sort.
Many thanks.
