Nobody will fix k series h/g
Discussion in 'Motoring Related Discussion' started by Stulc, May 19, 2019.
  1. Stulc
    Stulc Senior Member
    405
    7
    Nov 8, 2003
    In the hills
    Your Mercedes:
    W203 C180k
    Both mechanics I use said no, I've ordered the parts from Rimmer Bros and now don't know who to ask. A mate said I've good good mechanical knowledge and said fk them you do it then go to them in it when fixed.
    I'm tempted but really don't know, I've watched a few vids including one by John Paul of Rimmer Bros. Yes it's probably hard to do due to limited space, but I think still doable for a diy'er..... or is it still best last to the pros.
    If I can ****** find one that won't shy away from it.
    Seems to be that a lot of them just pick and choose ect.
  2. Craiglxviii
    Craiglxviii Senior Member
    14,418
    3,729
    Sep 6, 2015
    Cambs UK
    Your Mercedes:
    W215 CL500 Motorway Queen; W251 R320L Familybenz, S211 E320 Avg Designo Edition now sadly missed.
    I have to ask, but WTF you on about Lewis?!? ;)
    Rappey69, Conor and Dean Fletcher like this.
  3. OP
    Stulc
    Stulc Senior Member
    405
    7
    Nov 8, 2003
    In the hills
    Your Mercedes:
    W203 C180k
    Mgf 1.8i h/g
  4. Craiglxviii
    14,418
    3,729
    Sep 6, 2015
    Cambs UK
    Your Mercedes:
    What’s an h/g?
  5. PovertySpec
    PovertySpec Senior Member
    1,246
    173
    Mar 12, 2014
    Hampshire
    Your Mercedes:
    E220 CDi 07/57
  6. Yugguy
    Yugguy Senior Member
    2,241
    561
    Mar 4, 2016
    Rugby, UK
    Your Mercedes:
    C220CDI W204 Elegance Comand
    Find another mechanic?
  7. RhodiBill
    RhodiBill Senior Member
    379
    284
    Jan 30, 2019
    Central South Coast of England
    Your Mercedes:
    Mercedes 2003 R170 SLK230K
    Go here and ask - they will know of a few good Mechanics that will oblige to do your Rover K-Series HG. It's a common replacement on these.
    https://the75andztclub.co.uk/forum/
    I presume you got New Head Bolts because those will be needed as they are "one-use" only.
  8. OP
    Stulc
    Stulc Senior Member
    405
    7
    Nov 8, 2003
    In the hills
    Your Mercedes:
    W203 C180k
    I've been trying but nobody will do it
  9. OP
    Stulc
    Stulc Senior Member
    405
    7
    Nov 8, 2003
    In the hills
    Your Mercedes:
    W203 C180k
    Thanks but don't think they are active now
  10. ajlsl600
    ajlsl600 Senior Member
    3,037
    1,093
    Nov 18, 2013
    france
    Your Mercedes:
    clk3202001,sl6002003 with everything,A class 170cdi auto
    cant be that bad ,car is of age /design for humans to repair. somewhat different from a number of todays cars...
    DSK, Jim2 and vtaylor78 like this.
  11. RhodiBill
    379
    284
    Jan 30, 2019
    Your Mercedes:
    They are - go there. The Rover 75 and MGZT has the same K-Series engine in the 1.8....
  12. Uncle Benz
    Uncle Benz Senior Member
    2,494
    688
    Mar 31, 2006
    West Sussex
    Your Mercedes:
    Mainly Mercedes
    I've only encountered this engine in Caterhams, and they don't have a reputation for failure in that application. I have however had one or two apart myself. The job itself is no different really to most head gasket replacements, but often you will find if the engine has been badly overheated the centre two liners will have sunk into the block. The liner protrusion above the upper block height is crucial to sealing, so if the liners have sunk it will fail again in short order. The fix is a complete strip, and the liners need shims placing beneath them to lift them to the required height. Obviously this is a lot more work. A lot more.
    Wighty, Jim2 and malcolm210 like this.
  13. kid-jensen
    kid-jensen Senior Member
    893
    149
    Nov 13, 2002
    Epsom Downs, Surrey
    Your Mercedes:
    Ml320CDI 2007
    Most times it happens, putting in a rebuilt engine is cheaper than just replacing the head gasket and hoping for the best.
    Not cheap, but cheaper than the other option in the long run. A well rebuilt engine should get you 80K miles reliably, longer if you keep your eye on the temperature gauge and don't let the wife drive it.
  14. noonboots
    noonboots Senior Member
    211
    221
    Mar 17, 2018
    Your Mercedes:
    R230 SL 500 2003 M113 5.0l
    There are easier ways for garages to make money, than having to put a warranty on a job that might come back at them. I've done a lot of head gaskets on Rovers but not an MGF/TF. Looking at that video it's the same job just a little tight on access. As said, if they've been hot they can be a world of trouble but usually they blow chocolate mousse everywhere and get stopped before terminal damage can occur. . I used to buy 200 and 400 cars with blown gaskets very cheaply, sort them out and move them on. My son who was still at school did all the donkey work and I did the technical bits. Usually sold them on for double. He kept the profit.
  15. OP
    Stulc
    Stulc Senior Member
    405
    7
    Nov 8, 2003
    In the hills
    Your Mercedes:
    W203 C180k
    Well nobody I know will do it apart from a garage I don't know but I was going to get the parts from Rimmer anyway.
    If I'd known the guys I wouldn't do it I wouldn't have got it.
  16. OP
    Stulc
    Stulc Senior Member
    405
    7
    Nov 8, 2003
    In the hills
    Your Mercedes:
    W203 C180k
    Still nothing all I get is
  17. AMGeed
    AMGeed Senior Member
    5,502
    1,612
    Jan 18, 2009
    Poole, Dorset
    Your Mercedes:
    2004 W211 E55K ///AMG/ 2014 W212 E63 Biturbo
    Works fine for me. Try the URL from a proper PC instead of a phone.
  18. OP
    Stulc
    Stulc Senior Member
    405
    7
    Nov 8, 2003
    In the hills
    Your Mercedes:
    W203 C180k
  19. LostKiwi
    LostKiwi Senior Member
    19,097
    8,917
    Aug 25, 2006
    Your Mercedes:
    '93 500SL-32, '01 W210 Estate E240, 02 R230 SL500 (Malcolm Spec), 04 Smart Roadster Coupe
    Works fine for me on Android too
  20. Philedge
    Philedge Senior Member
    1,045
    40
    Sep 5, 2013
    Chester UK
    Your Mercedes:
    R230 SL500 2005
    I just clicked on the link from an android tablet and it worked ok.
Share This Page
