Noise from Automatic Transmission on W211 E280 Saloon (2005)
Discussion in 'Engine, Drivetrain, Fuel and Exhaust' started by allegoricus, Mar 28, 2019.
  1. allegoricus
    allegoricus New Member
    Jan 25, 2011
    West Sussex, England
    Your Mercedes:
    C280 W211 2005
    I'm hearing a low whine from the transmission that, gear-by-gear (automatic), raises in pitch as the car accelerates.
    The car's done around 110,000 miles.
    Can anyone advise what the problem is likely to be?
    Thanks,
    Peter
  2. Wighty
    Wighty Senior Member
    6,622
    3,764
    Aug 4, 2016
    Your Mercedes:
    Tyres excessively worn ? Maybe fit new ones .
    Rear differential wear , change the oil (cheap job)
    Change gearbox oil and filter if last change was in excess of 40k miles
  3. penton
    penton Senior Member
    49
    3
    Aug 30, 2011
    Harefield Middlesex
    Your Mercedes:
    W163 ML 2002 320 R170 slk 230 komp.
    Propshaft centre bearing is a possibility.
  4. Doug1234
    Doug1234 Senior Member
    556
    40
    Jun 28, 2009
    Bedfordshire uk
    Your Mercedes:
    1997 w210 e300td
    As mentioned it could be anything , noise travels in larger cars .
    For instance I once had a Bmw e34 that had a rattle from gearbox area so expected the exhaust support bracket to be bad but upon inspection was ok... forward a few months and under rear of car and crawling out I held onto rear exhaust pipe and it rattled and it turned out one captive mounting bolt needed a new washer as it had been whittled away and had a 3mm gap which let it squeak over light bumps.
  5. matthew k
    matthew k Senior Member
    269
    75
    Feb 4, 2015
    Winchester Hampshire
    Your Mercedes:
    2005 320 cdi Sport 7 seat estate
    How loud is it? My 2005 E320 (722.9) makes some slight whining noises at low speed that I attribute to the gearbox. Hasn't gotten any worse in 9,000 miles so I've ignored it.
  6. rifiki
    rifiki Senior Member
    276
    75
    Dec 29, 2015
    Worksop
    Your Mercedes:
    clk W209 Ponton 190
    Same on my 7 gear CLK, if it ain’t broke xxxxxx
    matthew k likes this.
  7. Steve@Avantgarde
    Steve@Avantgarde Forum Supporter Authorised Forum Supporter
    6,808
    959
    Dec 8, 2009
    Bristol/Somerset
    Your Mercedes:
    C220CDI AMG Line Premium, SLR McLaren Roadster, SL55 & C32AMG
    Prop bearing or a clip that holds the parking brake cable away from the prop shaft...
Share This Page
