noise inside the car
basamir
Barcelona
W202 from 07/1997
when I pass on a road with bumps and irregularities, I feel tje irregularity inside the car. I changed my front shock absorbers and some silent block and yet the noise persists.
B
basamir
Barcelona
W202 from 07/1997
i was chek springs there are very good and the part 8 was changed 6 months ago!!!
B
basamir
Barcelona
W202 from 07/1997
hi television,
maybe the RUBBER MOUNTING of trosion bar is the cause of this feeling no??
That rubber is well known to be the reason. I thought that you had a new one on the car
B
basamir
Barcelona
W202 from 07/1997
unfortunately not. You think that I can change them me even if yes how to make?
in your opinion has which are the other bodies likely to cause this noise felt at the wheel and in interior of the car ?
B
basamir
Barcelona
W202 from 07/1997
do you know how can i do it what's the first and last step plz?
The hard job is to be sure that you can take out bolts 35-32.
Ask me on Monday and I will send you a paper on how to do it
B
basamir
Barcelona
W202 from 07/1997
32 & 35 are just a screw no?
kth286
E320 Coupe 95
If it is through the steering you are feeling the vibration, perhaps the oil has leaked out of the steering damper.
Undo one of the two bolts and push the damper in and out and feel if resistence still there or not.
B
basamir
Barcelona
W202 from 07/1997
the steering damper is ok!!!!
B
basamir
Barcelona
W202 from 07/1997
10x television.
Can you tell me plz if part number 5 can be rectified following a deformation due to the bad roadway or to a blow of pavement?
Yes 5 can be damaged by a pavement or large hole in the road
8 is the one that wears out, but I think that you changed this
B
basamir
Barcelona
W202 from 07/1997
yes i changed part number 8 but now the guy of parallelism and set said me that part number 5 is twisted and that I must rectify it. Is this rectified with a press?
Only a new one, they are not too much money
B
basamir
Barcelona
W202 from 07/1997
  • #20
ok that's a good idea.
How to ensure what this part from a broken car is good and available ?
