non standard fogs ?
L
longlostpoet
i have 1997, E 300, W210 Auto Estate, Turbo Diesel.
both fog lights are badly corroded and need replacing.
problem is that when i check fogs that are listed, they appear to be a different shape.
suggested shape is rather square whereas my fitted fogs are 'eye' shaped ?
was there an early change of these lights or has a previous owner had a prang and replaced the front valance with a newer one, hence newer fogs.
is only way to tell what i've got... to remove them to obtain part number ?
next question:
is removal an easy operation ?
If your car is fitted with the AMG body kit, then the fog lamps are oval/eye shaped, the worst part is no parts for these, just complete new lamps.
L
longlostpoet
AMG ?
thanks for reply,
not an AMG version just normal spec except for the pair of front fogs.
i am prepared to buy new parts as complete corrosion has ruined them...
are they easy to get out or is it a garage job ?
bob 6600
Audi S8 V10, S210 E320 CDI (R.I.P.)
Malcolm is correct and it may be that your vehicle has an AMG bumper fitted
They are easy to remove....remove undershield and a couple of bolts/screws
Pre-facelift (yours)
Post-facelift
AMG
L
longlostpoet
easy ident now
thanks bob6600,
easy to id now, thanks to the pictures.
def not AMG
fairly sure it is the second picture, post facelift.
thanks
Its no good me putting up EPC pictures as they do not show the differences.
www.W140.co.uk&www.r129.co
