j.taylor2299
- Feb 19, 2024
- Age
- 31
- Location
- Galashiels
- C-Class 220D - 2016 (W205)
Hello
I am having issues with my W205 C Class 2.2 Diesel.
Around 6 months ago, I got the error stop car and keep engine running, so I bought a new battery.
Problems solved and even the start stop starting working for a few days then stopped (start stop never worked since I’ve had the car)
Now I’m getting issues starting, sometimes when I go to start it, it will crank over, then stop, it will do this several times but will eventually start.
Other times it starts no problem,
When it does the starting issues, I get all errors like abs, traction control etc, but a little rev and it goes away. Also the radio/command unit goes off, and won’t turn on again for a few minutes.
I have just replaced the auxiliary battery thinking this may be the problem but nothing has changed with that.
I have tested the main battery with a tester and seems to be holding a charge, multi meter tests show 12.7 normal with 13.8 with engine running.
So I am struggling now and not sure what to do next? Maybe alternator?
Any help would be appreciated
