Not a Merc but need advice please
MissyD
Essex init
www.depop.com
E200 1993, E300 Coupe 2019
My son (bless him!) was working on one of his cars when the axle stands propping it up gave way. As you can see in the pics the wheels where off to do the work and so when the axle stands gave way the car dropped so low into the gravel he isnt able to get a jack under it!
Any suggestions as to how he can get the car back up please, boys eh :mad:, think he should stick to selling them.
Beaucoupnice
Ouch!! what a bugger. Perhaps dig a hole underneath a jacking point. Put a brick in the hole and put the jack on it. lift it up to a safe height and place bricks under to stabilise it. Lower jack, remove it and relocate to another jacking point where there is no hole. Put wheels back on and move car to a hard surface and keep hand brake on and put a brick behind wheels to stop it doing it again. :D
You will be able to lift it an inch or two by by using a scaffold plank with the end dug under the suspension, or a hefty piece of timber in under the front suspension, you can remove the gravel to do this, then place the plank on a brick or piece of 4 x 4 wood placed near to the car,so the the end of the plank or wood under the suspension you can lever up the car a few inches, then put blocks under the wheel hub. it will be a few inches at a time and can be done, just keep lifting a little at a time. I have done it this way
mikestrivens
Stockport
Get two strong lads to lift it with their hands. Many years ago my Aunty drove over a ledge in a carpark and a couple of local lads just picked it up and put it back. Failing local muscle a lever under the jacking point should give you enough clearance to get a scissor jack under once you (sorry he) have dug out some of the gravel. I wouldn't like to try this with my V12.
Looks like a good exercise in physics for your son. Who said education doesn't pay.
Yes just one person standing with their back to the wheel arch can lift it a few inches, the block it,only one side at a time though
MissyD
MissyD
Essex init
www.depop.com
thanks mike, like that time he changed the wheels on a Peugeot I had, I couldnt drive it because they werent the correct size, but he said 'they look good tho!' I dont let him anywhere near my Merc :cool:
mikestrivens
Stockport
I find aesthetics and physics are incompatible sciences. Just look at NASA.
Rory
Cheshire, UK
You've had the suggestions about lifting it again, but did he have the axle stands standing on the gravel? That's incredibly dangerous.
Also, when the car is lifted and the wheels taken off, they should be slid under the sills, so if the axles stands do slip then the car only drops on to the wheels. It might mess them up but it could save your sons life or at least an arm, if he's working under the car.
Miffy
Bromley, London
CLK 320 CAB Elegance C208
Thankfully he wasnt working on the car at the time
mikestrivens
Stockport
Could be a candidate for the Darwin Awards :)
turbopete
Spennymoor
ive heard of lowering, but thats ridiculous!
kebo57
Lanc's
ml270
Hi lift the bonnet drop a bottle jack in somewhere maybe under the anti rollbar,
maybe lift the back up as far as possible then put some blocks / maybe the wheels under the chassis as near to the front as possible (each side) then lower the back down get some fat bloke to sit on the back then it might rock the front up of the ground
Kevin
Kevin
You cannot jack near the roll bar,it will just bend
turbopete
Spennymoor
should be ok if the jack is placed on the mounting bracket where its attached to the body
MissyD
MissyD
Essex init
www.depop.com
...... get some fat bloke to sit on the back then it might rock the front up of the ground
Kevin
thanks Kevin, thats what I love about this forum, the different levels of technical advice - you've reached my level :shock:
*wanted - one fat bloke!
Sarah I didn't realise you were in Halifax today :confused:
Alex M Grieve
Broom, Warwickshire
Problem is that, when volunteers are invited in the old "B" movies, only unmarried men need apply!
kebo57
Lanc's
ml270
Should be ok I do a lot of this
I don't bother much with jacking on small cars, I have a 1 ton overhead electric hoist with a girder trolley on a RSJ, I just drop a sling down with a bite around the anti roll bar and lift the whole front up 2ft our 3ft seam to work OK.
Kevin
www.ckinsurance.co.uk
