NTG 2.5 Scrambled Sat Nav.
Discussion in 'Electrics, Vacuum, Ignition and ECU' started by Happiechappie, Nov 11, 2012.
  1. Happiechappie
    Happiechappie Senior Member
    63
    Oct 5, 2009
    Your Mercedes:
    E320 CDI Sport
    Hi Folks
    This sat nav is in a 2008 W211. Its a 2008 model (added to the car as an update from Audio 20)with the latest firmware standard and 2010 maps. Its lost its way several times lately. It behaves ok then suddernly it tells me I'm off road, looses the map picture but the car symbol is still being driven what looks like cross country. The point where it gets scrambled can be on wide open roads where GPS reception would not be affected. It occasionally picks up new roads and provides voice direction but the position bears no relationship with where I am. Assuming the TMC symbol and the five squares in the lower right of the display show GPS reception, the reception can go from no squares to all squares but the system does not recover. The symptoms can last several days then suddernly, map mode with and without navigation directions operates normally. I can change the GPS antenna but other than that I'm lost. Any idea what might cause these symptoms ?
  2. television
    television Always remembered RIP
    164,074
    310
    Your Mercedes:
    You fault is the GPS antenna :D:D good fun isnt it when it shows you being in another place
  3. OP
    Happiechappie
    63
    Oct 5, 2009
    Your Mercedes:
    E320 CDI Sport
    not much fun when in the middle of Exeter!!!
    I assume there must be a range of antenna available. Is there a recommended best model?
  4. television
    164,074
    310
    Your Mercedes:
    Just get one from Ebay with a facra connector and pop it under the dash where there is no metal, that should enable you to get out of Exeter
  5. OP
    Happiechappie
    63
    Oct 5, 2009
    Your Mercedes:
    E320 CDI Sport
    Thank you Television. I will take your advice. Keith:)
  6. Rob law
    Rob law Senior Member
    106
    Dec 6, 2010
    Wales and USA
    Your Mercedes:
    CLS 320
    Sat Nav
    A common fault, had the same problem, as Television states buy a new one from Ebay with the connection FARCA around 15 pound, plug in and should sort your problem
Share This Page
