O2, Cam and crankshaft faults....
Mattevans101
Reading, Berkshire
Mercedes Vito 2009 115
Good evening,
i wondered if i could ask for some advice and help. i have a 2009vito 115.
THe MPG is down, along with a rough idle. The injectors have all been replaced (due to black death, with Bosch injectors and coded appropriately)
The codes i have which return when cleared are
P0135 o2 Sensor heater circuit
P2243 o2 Sensor reference voltage circuit open
P0336 Crankshaft sensor circuit A range performance
P0341 Camshaft Position sensor circuit range performance
This has had a new O2 sensor about 12 months ago, along with a new crankshaft sensor.....
do i need to look at replacing again? wiring? any other areas to look please.
I'd be getting the camshaft timing checked. That engine is known for chain stretch and sprocket wear.
