larry1985
- Sep 5, 2021
- c250
Hi all
Firstly I want to say that I am aware that this error code could be a few things, so I've taken the front bumper off and the RH intercooler pipe to look for tears, as it appears that the whooshing noise I'm hearing is coming from there, however the pipe looks ok, no obvious splits, ha ent checked drivers side pipe yet into turbo itself. Is it normal to see oil either end of said pipe? Also there seems to be some oil around the bottom area of where the pipe goes into the engine (sump?) So I'm wondering where else this air leak could be coming from if not from either pipe? And would the error code be different if from inlet mani?
